projekteja:olkiluoto3torttu [19.04.2023 13:41] – Robert Rozanski | projekteja:olkiluoto3torttu [19.04.2023 22:21] – Robert Rozanski | ||
====== Olkiluoto3torttu ====== | ====== Olkiluoto3torttu ====== | ||
- | The third unit of the Olkiluoto power plant has finally started | + | The third unit of the Olkiluoto power plant has finally started |
The structure of the cake is inspired by the look of the power plant: alternating brown and white mousse layers sandwiched between black base and topping: | The structure of the cake is inspired by the look of the power plant: alternating brown and white mousse layers sandwiched between black base and topping: | ||
Line 44: | Line 44: | ||
- Put the remaining 7 biscuits and 30g of tahini into the chopper, mix/chop as previously | - Put the remaining 7 biscuits and 30g of tahini into the chopper, mix/chop as previously | ||
- Keep the mix in the fridge for later use | - Keep the mix in the fridge for later use | ||
- | - Clean the | + | - Clean the chopper - you will need it later for the hazelnuts |
- The hazelnut butter/ | - The hazelnut butter/ | ||
- Roast the hazelnuts: you can use temperature between 150-175°C, the higher the quicker is the process, but also the easier it is to overdo the roasting. The peels should crack and the nuts should get light brown/ | - Roast the hazelnuts: you can use temperature between 150-175°C, the higher the quicker is the process, but also the easier it is to overdo the roasting. The peels should crack and the nuts should get light brown/ |
