projekteja:tietokonsoli [21.07.2021 01:12] – Luminix | projekteja:tietokonsoli [21.07.2021 01:14] (current) – Luminix | ||
Line 3: | Line 3: | ||
In the entry way between the woodworking rooms and textile room is a HP Slate 21 (it is under the monitor with the bus schedule and other info). It runs on Android Kitkat 4.4.2. ([[Wikipedia|https:// | In the entry way between the woodworking rooms and textile room is a HP Slate 21 (it is under the monitor with the bus schedule and other info). It runs on Android Kitkat 4.4.2. ([[Wikipedia|https:// | ||
- | It can be used to monitor environment at Hacklab: | + | It can be used to monitor |
- | - lights | + | |
- | - ventilation | + | |
- | - air quality | + | |
- | - sound levels | + | |
- | These elements and sensors need controllers to feed the data to a SBC (Single Board Computer) which processes the measurements and sends it to the HP Slate. | + | These elements and sensors need controllers to feed the data to an SBC (Single Board Computer) which processes the measurements and sends it to the HP Slate. |
Hacklab did have one Raspberry Pi for that, but that project has been outdated. Here is the link: | Hacklab did have one Raspberry Pi for that, but that project has been outdated. Here is the link: | ||
[[tyotilat: | [[tyotilat: |
