tyokaluja:laserleikkuri [10.02.2023 17:00] – added English for Starting the Laser Cutter Holly Poer | tyokaluja:laserleikkuri [20.02.2024 11:24] (current) – [Vinkkejä] Otto Laitinen | ||
+ | {{ file: | ||
====== Laserleikkuri | ====== Laserleikkuri | ||
- | {{ file: | + | \\ |
+ | ^ Laserleikkuri | ||
+ | |Name | Yilong Ping Pong | | ||
+ | |Manufacturer| Yilong | | ||
+ | |Type | Laser Cutter | | ||
+ | |Location | Entrance corridor | | ||
- | ======= Kuvaus ======= | + | ======= Kuvaus |
Yilong Ping Pong -laserleikkuri | Yilong Ping Pong -laserleikkuri | ||
Line 15: | Line 23: | ||
- | ======= Materiaalit ======= | + | ======= Materiaalit |
Älä leikkaa materiaalia, | Älä leikkaa materiaalia, | ||
Line 74: | Line 82: | ||
- | English: | + | //English:// |
- | - Turn on the main power from the switch on the wall (the white “Laser | + | - Turn on the main power from the switch on the wall (//the white “Laser |
+ | - Turn on the Chiller which sits on the floor, under the control computer, to the right of the laser cutter. | ||
- Turn on the laser from the red switch on the right side of the device. {{file: | - Turn on the laser from the red switch on the right side of the device. {{file: | ||
- If the laser does not start buzzing, pull out the red emergency stop switch by rotating it. | - If the laser does not start buzzing, pull out the red emergency stop switch by rotating it. | ||
- Start the control computer. | - Start the control computer. | ||
- Wait for the computer to start, the login will happen automatically. | - Wait for the computer to start, the login will happen automatically. | ||
- | - Start the Laserweb | + | - Start the LightBurn |
- Make sure there is nothing on the cutting platform that will block the movement of the laser cutter axes. | - Make sure there is nothing on the cutting platform that will block the movement of the laser cutter axes. | ||
- Press the Comms tab on the left and the Connect tab. | - Press the Comms tab on the left and the Connect tab. | ||
Line 91: | Line 100: | ||
+ | TODO: LightBurn instructions | ||
- | ======= Laserwebin käyttö ======= | + | ======= Laserwebin käyttö |
Line 100: | Line 110: | ||
- | ====== G-koodin valmistelu ====== | + | ====== G-koodin valmistelu |
Line 111: | Line 121: | ||
- | ===== Bittikartat ===== | + | ===== Bittikartat |
Line 132: | Line 142: | ||
{{file: | {{file: | ||
- | ====== Leikkaus ====== | + | ====== Leikkaus |
{{ tyokaluja: | {{ tyokaluja: | ||
- | - Paina "Set zero" | + | |- Siirry Control-välilehteen vasemmalta. Laita kappale alustalle ja siirrä leikkuupää aloituskohtaan nuolilla. Keypadin 4,8,2,6 toimii myös, mutta älä pidä niitä pohjassa.| |Go to the Control tab on the left. Place the piece on the base and use the arrows to move the cutting head to the starting point. 4,8,2,6 on the keypad will also work, but don't keep them on the bottom.| |
- | - Paina "Check size". Laser kiertää koko leikkuualan. Varmista että leikattava levy on tarpeeksi iso. | + | |- Paina "Set zero".| |Press “Set zero”.| |
- | - Kytke leikkurin paneelissa oleva BEAM ENABLE kytkin päälle. --> | + | |- Paina "Check size". Laser kiertää koko leikkuualan. Varmista että leikattava levy on tarpeeksi iso.| |Press “Check size”. The laser goes around the entire cutting area. Make sure the board to be cut is big enough.| |
- | - Paina "Run Job". Leikkaus alkaa. | + | |- Kytke leikkurin paneelissa oleva BEAM ENABLE kytkin päälle. -->| |Turn on the BEAM ENABLE switch on the cutter panel. –>| |
- | - Leikkauksen lopuksi laita BEAM ENABLE pois päältä. | + | |- Paina "Run Job". Leikkaus alkaa. |
+ | |- Leikkauksen lopuksi laita BEAM ENABLE pois päältä.| |At the end of the cut, turn off BEAM ENABLE.| | ||
====== Kun kone sekoaa ====== | ====== Kun kone sekoaa ====== | ||
Line 153: | Line 165: | ||
- | ======= Leikkuuteho ja nopeus ======= | + | ======= Leikkuuteho ja nopeus |
Linssin puhtaus vaikuttaa tehoon huomattavasti. Jos epäilet linssin olevan likainen, ilmoita Arnolle. Linssin väärä käsittely tuhoaa linssin pinnoitteen. | Linssin puhtaus vaikuttaa tehoon huomattavasti. Jos epäilet linssin olevan likainen, ilmoita Arnolle. Linssin väärä käsittely tuhoaa linssin pinnoitteen. | ||
Line 202: | Line 214: | ||
-jos käytät Fusionia kappaleiden tekoon, nii fusionista saa [[https:// | -jos käytät Fusionia kappaleiden tekoon, nii fusionista saa [[https:// | ||
- | ======= Koneen huolto ======= | + | -Deepnest ohjelmalla voit optimoida käytetyn materiaalin määrän. https:// |
+ | ======= Koneen huolto | ||
+ | ^Pedin puhdistus ^ ^ Bed cleaning^ | ||
+ | |- Irroita alumiiniprofiilit | ||
+ | |- Aseta alumiiniprofiilit astiaan johon ne mahtuvat (loistevalon kupu toimii, tarkoitukseen valmistettu astia voisi myös olla hyvä) | |- Place the aluminum profiles in a container that fits them (a fluorescent light dome works, a purpose-made container could also be good) | | ||
+ | |- Laita astiaan konetiskiainetabletti / jauhetta | |- Put a dishwasher tablet / powder in the container| | ||
+ | |- Lisää kuumaa vettä | |- Add hot water| | ||
+ | |- Anna liueta tovi. esim. 15min | |- Let it dissolve for a while. e.g. 15 min| | ||
+ | |- Hankaa lika irti esim. rst hankaussienellä. Käytä suojakäsineitä | |- Rub the dirt off, e.g. first with a scrubbing sponge. Use protective gloves | | ||
+ | |- Huuhtele ja kuivaa profiilit | |- Rinse and dry the profiles | | ||
+ | |- Imuroi koneen sisusta | |- Vacuum the inside of the machine | | ||
+ | |- Aseta profiilit takaisin paikalleen | |- Put the profiles back in place| | ||
Line 234: | Line 257: | ||
- | ======= Käytön jälkeen ======= | + | ======= Käytön jälkeen |
Olisi suotavaa. Siivota jälkensä, jos muilla paikan päällä ei ole laserille käyttöä sammuta se. Jos käytön aikana ilmeni ongelmia ilmoita niistä telegrammiin, | Olisi suotavaa. Siivota jälkensä, jos muilla paikan päällä ei ole laserille käyttöä sammuta se. Jos käytön aikana ilmeni ongelmia ilmoita niistä telegrammiin, | ||
+ | //It would be desirable. Clean up after yourself, if others on site have no use for the laser turn it off. If problems occur during use, report them to telegram, irk or the email list (at least in the error booklet in the hall). Fill in the logbook (there is a gray notebook hanging next to the laser) what you did, how long you did it, at what power and how successful it was. For example, Lasse Laser cut 3 mm plywood with 600 feed and 50% power for about an hour, it cut well. In this way, valuable information can be collected in the log book, which can be useful to fellow members.// | ||
