Next revision | Previous revisionNext revisionBoth sides next revision | ||
tyokaluja:ompelukoneet [14.10.2021 17:24] – created sandplum | tyokaluja:ompelukoneet [21.10.2021 17:38] – added Singer 714 manual sandplum | ||
Line 4: | Line 4: | ||
- | === Juki DDL-8500 lukkotikkikone – industrial sewing machines === | + | === Juki DDL-8500 lukkotikkikone – industrial |
+ | == LOCKSTITCH or STRAIGHT SEWING MACHINES | ||
+ | * When winding, | ||
=== Rimoldi 27.01 saumuri joustava – 3-thread overlocker machine === | === Rimoldi 27.01 saumuri joustava – 3-thread overlocker machine === | ||
=== Union Special saumuri === | === Union Special saumuri === | ||
=== Strobel === | === Strobel === | ||
+ | == Singer == | ||
