tyokaluja:ompelukoneet [14.10.2021 17:39] – added images sandplum | tyokaluja:ompelukoneet [02.11.2021 17:53] – added image of machine needles sandplum | ||
Line 6: | Line 6: | ||
=== Juki DDL-8500 lukkotikkikone – industrial sewing machine === | === Juki DDL-8500 lukkotikkikone – industrial sewing machine === | ||
+ | == LOCKSTITCH or STRAIGHT SEWING MACHINES == | ||
+ | * When winding, | ||
Line 23: | Line 59: | ||
+ | == Singer == | ||
