tyokaluja:ompelukoneet [15.10.2021 14:12] – added YouTube links sandplum | tyokaluja:ompelukoneet [02.11.2021 17:53] – added image of machine needles sandplum | ||
Line 8: | Line 8: | ||
- | [[https:// | + | [[https:// |
+ | == LOCKSTITCH or STRAIGHT SEWING MACHINES == | ||
+ | * When winding, | ||
Line 29: | Line 62: | ||
[[https:// | [[https:// | ||
+ | == Singer == | ||
