tyokaluja:ompelukoneet [15.10.2021 14:12] – added YouTube links sandplum | tyokaluja:ompelukoneet [18.07.2023 18:26] – Jenni Kuronen Neves | ||
Line 8: | Line 8: | ||
- | [[https:// | + | [[https:// |
+ | == LOCKSTITCH or STRAIGHT SEWING MACHINES == | ||
+ | * When winding, | ||
Line 16: | Line 49: | ||
+ | 18.7.2023 Kone muutettu 2-neulaiseksi ja 3-lankaiseksi. Langankatkaisuleikkuri poistettu. / | ||
Line 29: | Line 66: | ||
[[https:// | [[https:// | ||
+ | == Singer == | ||
