Next revision | Previous revisionLast revisionBoth sides next revision | ||
tyokaluja:sla-tulostin [23.06.2022 21:16] – created Pekka Oinas | tyokaluja:sla-tulostin [08.02.2024 16:50] – old revision restored (25.07.2023 11:35) Holly Poer | ||
- | *This article is a work in progress* | + | //An English language version of this article is available [[tyokaluja: |
- | ====== Elegoo Mars SLA-printer | + | ====== Elegoo Mars SLA-tulostin |
- | The hacklab has a first-generation Elegoo Mars SLA resin printer. The printer is located inside a fume hood in the painting room. | + | {{: |
- | ===== Printer Specifications ===== | + | Hacklabilla on ensimmäisen sukupolven Elegoo Mars hartsitulostin. Tulostin on maalaushuoneessa vetokaapissa. |
- | **Printing area:** 120 x 68 x 155 mm | + | ===== Tulostimen tekniset tiedot ===== |
- | **X/Y Resolution: | + | |
- | **Layer height:** Depends on resin; usually 0.05 mm | + | |
- | ===== Preparing the Model ===== | + | **Tulostusalue: |
+ | **X/Y -resoluutio: | ||
+ | **Kerroskorkeus: | ||
+ | **UV aallonpituus: | ||
- | You can print any 3D model as long as it fits in the print area. The most common file format is STL. Models can be found online or created using CAD software, Blender, etc. | + | ===== Mallin valmistelu ===== |
- | Models must be prepared using a slicing application before the printer can print them. The recommended application is ChiTuBox, which can be found on at least some of the computers at the lab. ChiTuBox can also add supports, make holes (for resin drainage) and hollow out the model (to conserve resin). Selecting the correct printer profile (Elegoo Mars) and the correct resin profile in ChiTuBox will give you workable default settings. If there is no profile for the resin you are using, consult the resin bottle. | + | Tulostimella voi tulostaa minkä tahansa 3D-mallin kunhan se mahtuu tulostusalueelle. Yleisin tiedostomuoto |
- | After the model is sliced, put it on the USB stick found attached to the printer, then plug the USB stick into the USB extension cable next to the printer. | + | Ennen tulostusta malli tulee slaissata käyttäen slaissaussoftaa. Tämä tehdään ChiTuBox-ohjelmalla, mutta huomioitavaa |
- | ===== Preparing the Printer ===== | + | Supporttien luominen PrusaSlicerissä hoituu seuraavasti. Aseta ohjelma SLA-tilaan vaihtamalla printteriprofiiliksi joko Elegoo Mars tai Prusa SL1 (ensimmäinen näistä on custom-profiili, |
+ | ChiTuBoxissa oikean tulostin- ja hartsiprofiilin valitsemalla saat toimivat oletusasetukset, | ||
+ | Kun malli on slaissattu, tallenna se printterissä (tai pikemminkin printterin vieressä olevassa USB-jatkojohdossa) kiinni olevalle USB-tikulle ja laita tikku sitten takaisin kiinni printteriin. | ||
+ | ===== Tulostimen käyttö ===== | ||
+ | ==== Hartsiturvallisuus ja -hygienia ==== | ||
+ | **HARTSIN KANSSA LÄTRÄTESSÄ KÄYTETÄÄN //AINA// SUOJALASEJA. EI MUTTIA.** Mielellään sellaisia silmät sivultakin suojaavia. | ||
+ | Hartsi on yleisesti ottaen melko myrkkyä (kuten pullossa olevat hieroglyfit kertovat). Käytä aina suojalaseja kun työskentelet printterin parissa äläkä koske hartsiin paljain ruumiinosin äläkä varsinkaan järkkää sitä silmiisi tai suuhusi. Hartsin välittömiin vaikutuksiin lukeutuvat kemialliset palovammat. Se ei ole riittävän väkevää polttamaan ihoa välittömästi, | ||
+ | Pitkällä aikavälillä hartsi on allergisoivaa ja kontakti voi kehittyä hartsiallergiaksi vaikkei sinulla sitä entuudestaan olisi. Tämä on toinen hyvä syy pitää se pois iholta. | ||
+ | Hyvin tuuletetussa huoneessa hartsin käryt eivät ole kovinkaan vaarallisia eivätkä turvaohjeet yleensä pidä hengityssuojaimia tarpeellisina. IPA-käryt, joita printtejä puhdistaessa vapautuu, ovat hartsia ikävämpiä, | ||
+ | Hartsin ja kovettamattomien tulosteiden kanssa työskennellessä on hyvä seurata puhtaan ja likaisen käden periaatetta. Toiseen käteen laitetaan nitriilihanska, | ||
+ | Kun noudattaa turvaohjeita, | ||
+ | ==== Tulostimen valmistelu ==== | ||
+ | Kytke tulostin päälle sen takapuolella olevasta virtakytkimestä. Nosta punainen suojakupu pois. | ||
+ | Katso tulostimen pohjalla olevaan hartsiammeeseen. Luultavasti siellä on jo hartsia, joka on ihan OK koska hartsi säilyy hyvänä kuvun alla useita viikkoja. Se voi kuitenkin kerrostua, joten ammeessa oleva hartsi tulee sekoittaa ennen käyttöä ja samalla katsoa, ettei siellä kellu mitään kovettuneita sattumia jotka voivat pilata printin. Helpoin tapa tehdä tämä on vetää nitriilihanska käteen ja sekoittaa hartsia varovasti sormella kunnes väri tasoittuu. Jos hartsi näyttää jo yksiväriseltä, | ||
+ | Jos ammeessa oleva hartsi on mennyt huonoksi( ollut pitkään ja nesteste ei ole tasavärinen), | ||
+ | **TODO: kuinka hartsi vaihdetaan** | ||
+ | Varmista että tulostuslevy (ylhäällä roikkuva osa, joka liikkuu ylös ja alas hartsissa) on asetettu kunnolla loppuun asti, on kiinni ja kiristetty. | ||
+ | **TODO: milloin Z-akseli tarvitsee nollata ja kuinka se nollataan** | ||
+ | Laita punainen suojakupu takaisin tulostimen päälle. | ||
+ | ==== Tulostaminen ==== | ||
+ | Valitse kosketusnäytöltä tiedosto, jonka haluat tulostaa. Varmista esikatselusta että se on oikea tiedosto ja paina starttia. | ||
+ | Seuraa ensimmäisen muutaman kerroksen tulostamista varmistuaksesi siitä, että kaikki on OK. Tulostuslevyn pitäisi laskeutua hartsiin, mennä pohjalle asti, nousta pikkusen matkaa ylös ja sitten laskeutua takaisin pohjalle, jossa se pysyy 60 sekuntia (tai mitenkä pitkän valotusajan asetitkaan pohjakerroksille). Tämä prosessi toistuu 4 kertaa (tai montako pohjakerrosta asetitkaan), | ||
+ | ==== Tulosteen irrottaminen ==== | ||
+ | Kun tulostus on valmis, tulostuslevy nousee maksimikorkeudelle ja pysyy siinä. | ||
+ | Tässä vaiheessa laitetaan (taas) suojalasit päähän ja vedetään hanska käteen, niinkuin turvallisuuskohdassa puhuttiin. Löysää puhtaalla kädellä tulostimen yläosassa oleva iso ruuvi ja liu' | ||
+ | Raaputinlastaa käyttäen irroita printti varoen tulostuslevystä. Levyä on OK käsitellä metallityökalulla, | ||
+ | ==== Tulosteen puhdistaminen ==== | ||
+ | Tulostimen vierestä löytyy Anycubic Wash and Cure -kone, jolla pestään ja kovetetaan tulosteet. Nosta koneen keltainen muovikupu pois. **Älä koske muovikupuun tai mihinkään koneen osaan likaisella hanskakädelläsi.** Poista ison puhdistusrasian kansi ja aseta rasia puhdistuskoneeseen. Koneen pohjalla on matalat reunat joiden avulla rasian saa paikalleen, mutta mekaanista yhteyttä ei ole; rasian pohjalla olevaa propellia pyöritetään magneeteilla. | ||
+ | Laita tulosteesi metalliseen pesukoriin ja laske kori puhdistusainesammioon. Korin kahva menee koneen yläreunassa oleviin pidikkeisiin. Laita kone Wash-tilaan alareunan hallintapaneelista ja aseta haluamasi aika pesuohjelmalle (2 tai 4 minuuttia pitäisi riittää). Käynnistä pesuohjelma ja odota että kone ilmoittaa sen loppumisesta piippaamalla. | ||
+ | Kun pesu on suoritettu, poista printtisi pesukorista ja sitten poista pesukori sammiosta, kolistellen sitä vähän sammion reunoihin että enimmät pesunesteet ja irralliset muovinpalaset jäävät jälkeen. Mikäli printissäsi on reikiä/ | ||
+ | Putsaa tulosteesi loppuun pyyhkimällä paperilla pesuaineet pois ja poistamalla irralliset muovinpalaset. Laita akryylinen pyöritysalusta Anycubicin sisään; se asettuu pohjalla olevaan akseliin. Laita tuloste alustalle ja sulje koneen kansi. Aseta kone Cure-tilaan, | ||
+ | Tuloste pitäisi nyt olla valmis. | ||
+ | ==== Siivoaminen ==== | ||
+ | Puhdista jokainen käyttämäsi työkalu IPA:lla ja paperilla pyyhkimällä. Puhdista tulostuslevyn molemmat puolet ja kiinnitä se takaisin tulostimeen. Siivoa roiskeet, ympäriinsä lennelleet muovinpalaset yms. Laita likaiset käsipaperit ja hanskat sekajätteeseen. **Levitä työpisteelle uudet paperit pöydän ja tarjottimen suojaksi sotkemiesi tilalle.** Tulostimesta pitää käytön jälkeen tehdä siistimpi, kuin mitä se oli käyttöä ennen. | ||
