tyokaluja:tarraleikkuri [12.03.2023 20:09] – Aku Savolainen | tyokaluja:tarraleikkuri [15.03.2023 14:00] – added image of vinyl rolls and work area Holly Poer | ||
- | ====== Tarraleikkuri Summa D60R ====== | + | ====== Tarraleikkuri Summa D60R -- Vinyl Cutter |
Uusi ja hieno joukkorahoitettu tarraleikkuri Summa D60R. | Uusi ja hieno joukkorahoitettu tarraleikkuri Summa D60R. | ||
TODO | TODO | ||
Line 27: | Line 29: | ||
- Weed and transfer: After cutting, weed out the excess vinyl using a weeding tool, leaving only the desired design. Then use a transfer tape to lift the design from the backing and transfer it to the desired surface. | - Weed and transfer: After cutting, weed out the excess vinyl using a weeding tool, leaving only the desired design. Then use a transfer tape to lift the design from the backing and transfer it to the desired surface. | ||
===== Materiaalit ===== | ===== Materiaalit ===== |
