en:palvelut:matrix [19.07.2026 22:10] – [Element for Mobile devices] Jana Lumien:palvelut:matrix [19.07.2026 22:15] (current) – [Element for Mobile devices] Jana Lumi
-FIXME **This page is not translated, yet. Please help completing the translation.**\\ //(remove this paragraph once the translation is finished)// +{{ :matrix_idea.jpg?300&direct}}[[https://matrix.org/|Matrix]] is an open source, decentralised, modern and secure instant messaging protocol that allows you to connect to hacklab's instant messaging channels as well as many other platforms via so-called [[https://matrix.org/bridges/|Bridges]]. In simple terms, the Matrix server is connected to a web browser or a separate client program. There are several [[https://matrix.org/clients|different]] of them. One of the most used clients is [[https://element.io/|Element]]. The Element application is available for most platforms and operating systems, so we recommend using it for beginners.
-{{ :matrix_idea.jpg?300&direct}}[[https://matrix.org/|Matrix]] is an open source, decentralized, modern and secure instant messaging protocol that allows you to connect to hacklab's instant messaging channels as well as many other platforms via so-called [[https://matrix.org/bridges/|Bridges]]. In simple terms, the Matrix server is connected to a web browser or a separate client program. There are several [[https://matrix.org/clients|different]] of them. One of the most used clients is [[https://element.io/|Element]]. The Element application is available for most platforms and operating systems, so we recommend using it for beginners.+
 The Hacklab.fi umbrella organization maintains the Matrix [[https://matrix.hacklab.fi/|server]], which you can log in to with your member register credentials (SSO/Keycloak). The Hacklab.fi umbrella organization maintains the Matrix [[https://matrix.hacklab.fi/|server]], which you can log in to with your member register credentials (SSO/Keycloak).
Line 17: Line 15:
   - Install the Element app. **Please note that you do not need to create a new account during installation !**\\ \\ [[https://apps.apple.com/app/vector/id1083446067|{{:palvelut:appstore.png?x150}}]] [[https://play.google.com/store/apps/details?id=im.vector.app|{{:palvelut:getitongoogleplay_badge_web_color_english.png?x150}}]] [[https://f-droid.org/repository/browse/?fdid=im.vector.app|{{:palvelut:get_it_on_f-droid-_badge-p-500.png?x150}}]] \\ ‎    - Install the Element app. **Please note that you do not need to create a new account during installation !**\\ \\ [[https://apps.apple.com/app/vector/id1083446067|{{:palvelut:appstore.png?x150}}]] [[https://play.google.com/store/apps/details?id=im.vector.app|{{:palvelut:getitongoogleplay_badge_web_color_english.png?x150}}]] [[https://f-droid.org/repository/browse/?fdid=im.vector.app|{{:palvelut:get_it_on_f-droid-_badge-p-500.png?x150}}]] \\ ‎
-  - Configure Element by pressing the button\\ \\ [[https://app.element.io/?hs_url=https://hacklab.fi|{{:palvelut:configure_element.png?150}}]] \\ ‎  +  - Configure Element by pressing the button\\ \\ [[https://app.element.io/?hs_url=https://hacklab.fi|{{:palvelut:configure_element.png?150}}]]
-  - Check that the server is changed to hacklab.fi (NOT matrix.org which is the default) \\ ‎   +  - Check that the server is changed to hacklab.fi (NOT matrix.org which is the default)
-  - Scroll to the bottom of the login window and select Hacklab SSO login \\ \\ {{:tunnukset.png?500&direct}} \\‎+  - Scroll to the bottom of the login window and select Hacklab SSO login \\ \\ {{:tunnukset.png?500&direct}}
   - Select Tampere and log in with your [[https://my.tampere.hacklab.fi/|member registration ID]].   - Select Tampere and log in with your [[https://my.tampere.hacklab.fi/|member registration ID]].
   - Logging in requires a token. ** [[?oauthlogin=keycloak|Click here]]** to log in to the Wiki and view your registration token.   - Logging in requires a token. ** [[?oauthlogin=keycloak|Click here]]** to log in to the Wiki and view your registration token.
Line 27: Line 25:
-==== Pikaohje (selainsovellus)  --  Quick Help (browser application) ====
-Pikaohje selainsovelluksen käyttöön.
 ==== Desktop browser ==== ==== Desktop browser ====
Line 45: Line 38:
-=== Element Desktop app ===+==== Element Desktop app ====
 Below are instructions for setting up device-specific Element applications and logging into the hacklab.fi matrix server. Below are instructions for setting up device-specific Element applications and logging into the hacklab.fi matrix server.
-**Element desktop application --  //Desktop//**\\+**Element desktop app --  //Desktop//**\\
   * Download and install the Element app [[https://element.io/get-started#download]]   * Download and install the Element app [[https://element.io/get-started#download]]
