tyokaluja:en:sla-printer [26.06.2022 14:00] – Pekka Oinas | tyokaluja:en:sla-printer [23.11.2024 16:04] (current) – Matias Moilanen | ||
- | ====== Elegoo Mars SLA-printer (resin printer) ====== | + | Read this and additionally, |
- | {{: | + | =====Formlabs Form 2 SLA Printer===== |
+ | \\ The Hacklab has a Formlabs Form 2 stereolithography (SLA) printer. The printer is located in the paint room in a fume hood. | ||
- | The hacklab has a first-generation Elegoo Mars SLA resin printer. The printer is located inside a fume hood in the painting room. | + | ====Printer Specifications==== |
- | ===== Printer Specifications ===== | + | * Printing area: 145 x 145 x 175 mm |
+ | * X/Y resolution: 140 microns (0.14 mm) | ||
+ | * Layer height: 25, 50, 100, 200 microns (0.025, 0.05, 0.1, 0.2 mm) | ||
+ | * UV wavelength: 405 nm | ||
- | **Printing area:** 120 x 68 x 155 mm\\ | + | ====Model Preparation==== |
- | **X/Y Resolution: | + | \\ You can print any 3D model with the printer as long as it fits within the printing area. The most common file format is STL. Models can be found online or created using CAD software, Blender, etc. Before printing, the model must be sliced using slicing software. This is done with the PreForm software, which is specifically designed for Formlabs printers. |
- | **Layer height:** Depends on resin; usually 0.05 mm\\ | + | |
- | ===== Preparing the Model ===== | + | ====Creating Supports==== |
+ | \\ Creating supports in the PreForm software is done as follows: Upload the STL model to the software and use the tools provided by the program to generate supports. PreForm can optimize the model' | ||
- | You can print any 3D model as long as it fits in the print area. The most common file format | + | |
+ | \\ WHEN HANDLING RESIN, ALWAYS WEAR SAFETY GLASSES. NO EXCEPTIONS. Preferably, choose glasses that also protect | ||
- | Models must be prepared | + | ====Preparing the Printer==== |
+ | \\ Turn on the printer | ||
- | To generate supports in PrusaSlicer, | + | ====Printing==== |
+ | \\ Select | ||
- | Selecting | + | ====Removing |
+ | \\ When the printing is complete, the build plate will rise to the maximum height | ||
- | After the model is sliced, put it on the USB stick found attached | + | ====Cleaning |
+ | \\ Check that there is enough isopropanol in the washer.\\ Unlock the build plate by lifting the lever on top. Move the build plate with the print to the washer.\\ Once the washing is complete, remove | ||
- | ===== Working with the Printer ===== | + | ====Cleaning Up==== |
+ | \\ Clean the used tools and build plate. Clean up any plastic pieces and splashes that may have scattered around. Keep the workspace tidy and safe. | ||
- | ==== Resin Safety & Hygiene | + | ====ProtoArt Universal Cartridge==== |
+ | \\ A ProtoArt Universal Cartridge has been acquired for the printer, allowing the use of third-party resins without losing the printer' | ||
+ | \\ %%https:// | ||
- | **ALWAYS WEAR SAFETY GOGGLES WHEN WORKING WITH RESIN. NO EXCUSES.** | + | \\ However, this does not completely free us; whenever changing resin types or after printing about 2 liters, this chip needs to be reset using the “cartridge configurator” found at the link above. ProtoArt offers 10 resets, and additional resets can be purchased for €45 for 10 resets. |
- | Resin is generally quite toxic (as the red warning symbols on the bottle suggest). Wear safety glasses at all times when working around | + | \\ **When using the Universal Cartridge, always check before starting a print that the bottom valve is not leaking. At the end of printing, check if the valve has let too much resin into the print tank, meaning |
- | In a ventilated area the fumes from the resin are not a major concern and safety sheets | + | \\ More information on compatible resins for available |
- | When working with resin and uncured prints, it is good to follow a clean hand & dirty hand hygiene practice. Wear a nitrile glove on one hand; this is the only hand that will ever touch resin, uncured prints, the working ends of tools, the build plate of the printer, and anything else that comes in direct contact with resin. Your other hand is the clean hand; this is the only hand that will ever touch tool handles, the printer or curing machine, or anything else that should not come in direct contact with resin. | ||
- | With appropriate precautions resin is easy to work with, so don't be too afraid of it. | ||
- | ==== Preparing the Printer ==== | ||
- | Turn the printer on using the power switch on the back side of the printer. Lift off the red plastic cover. | ||
- | Make sure there is resin in the resin basin at the bottom. Odds are there already is resin in the basin; this is fine, as the resin will stay good for many days or weeks. However, it separates over time, so you will have to mix the resin in the basin before printing, as well as make sure there aren't any hard bits of resin floating around in it. The easiest way to do this is to wear a nitrile glove and mix the resin with your finger until it becomes uniform in colour (if it appears uniform already, mix it anyway; it could just be pretending). | ||
- | If the resin in the basin has gone bad, you'll have to change it. **TODO: how to change the resin** | ||
- | Make sure the build plate (the part at the top that dips in and out of the resin) is attached and tightened. | ||
- | Set the red plastic cover back over the printer. | ||
- | ==== Printing ==== | ||
- | Select the file you want to print on the touchscreen. Verify that the preview looks about right and press start. | ||
- | Observe the first couple of layers to make sure everything is going OK. The build plate should descend into the resin, reach the bottom, lift up a little, then descend again to touch the bottom. It will remain there for about 60 seconds (whatever you set the first layer exposure time at). It will then repeat this for another 4 layers (or whatever you set the bottom layer count at). After that each layer will only be exposed for 8 seconds (or whatever you set the exposure time at). If things are still looking alright at this point and there are no weird crunching noises and resin isn't leaking out and the printer isn't on fire, it is safe to leave the printer unattended. You won't be able to actually see the print for a long time anyway as it will be upside down suspended in the resin. | ||
- | ==== Detaching the Print ==== | ||
- | Once the print is finished, the build plate will lift out of the resin to its maximum height and stay there. | ||
- | At this point put on your safety goggles and wear a nitrile glove on one hand as detailed in the resin hygiene section above. Loosen the big hand screw at the top of the printer using your clean hand, then detach the build plate by pulling it towards yourself -- it will slide off horizontally. The build plate is covered in resin, so only touch it with your gloved dirty hand. | ||
- | Using a scraper, carefully detach the part from the build plate. It is alright to scrape the build plate with a metal scraper, but do it gently at a low angle to not leave any deep marks and to avoid damaging your print. Remove any supports from the print and wipe off excess resin using a paper towel. | ||
- | ==== Cleaning the Print ==== | ||
- | Next to the printer is an Anycubic Wash and Cure machine, which is used for washing and curing prints. Remove the yellow plastic cover of the machine. **Do not touch the cover or any part of the machine or the container with your gloved dirty hand.** Take the lid off the large cleaning fluid (the fluid is isopropyl alcohol) container and place it in the Anycubic. There are little grooves to help you align it, but there is no mechanical connection; the mixer at the bottom is rotated using magnets. | ||
- | Put your print in the metal washing rack, then lower the rack into the cleaning fluid container. The handle fits into slots near the top of the machine. Put the yellow plastic cover on the machine. Set the machine to Wash mode using the control panel, and adjust the time to your liking (2 or 4 minutes should be enough). Start the machine and wait for the cleaning program to run. The machine will beep once the program is finished. | ||
- | After the program is finished, lift the rack up, remove your print, and then rattle the rack against the edges of the container to get most cleaning fluid and loose pieces of plastic off of it before hanging it back up on the tool rack you found it on. Close the container lid tightly. | ||
- | Finish cleaning your print up by hand by wiping off any remaining loose material and drying it using paper towels. Insert the acrylic platter into the Anycubic. It will slot into the axle at the bottom of the machine. Place your print on the acrylic platter and close the machine lid. Set the machine to Cure mode, adjust the timer to 6 minutes and press start. Once the program is done, flip your print upside down to expose the bottom and run it through the cure program again. | ||
- | Your print should now be done. | ||
- | ==== Cleaning Up ==== | ||
- | Clean every tool you used with isopropyl alcohol and paper towels. Clean both sides of the build plate and reattach it to the printer. Clean off any spills, bits of plastic etc. Put used paper towels and nitrile gloves in the trash. **Replace all the paper towels covering the work surfaces after you're done.** You should leave the printer nicer than you found it. |
