Next revision | Previous revision | ||
tyokaluja:ultraaeaenipesuri [28.10.2021 12:23] – created ats | tyokaluja:ultraaeaenipesuri [17.03.2024 12:31] (current) – [Ultraäänipesuri -- Ultrasonic Cleaner] Aku Savolainen | ||
- | ====== Ultraäänipesuri ====== | + | {{ : |
+ | ====== Ultraäänipesuri | ||
- | Kannattaa käyttää pestävien | + | HAJONNUT - HÄVITETTY 17.3.2024 |
+ | **HUOM!** Laitteen käyttö **tyhjällä** säiliöllä saattaa hajottaa laitteen.</ | ||
+ | NOTE! Using the appliance with an empty container may break the appliance. //</ | ||
+ | Specifications | ||
+ | Tank Material: Stainless Steel SUS304 | ||
+ | Heating Power: 600W | ||
+ | Ultrasonic Power: 600W | ||
+ | Frequency: 40kHz | ||
+ | Power Supply: AC110V 60Hz | ||
+ | Tank Capacity: 26-30L (Since the bottom of the ultrasonic cleaner is a curved surface, the actual volume will be smaller.) | ||
+ | Time Setting: 0 - 30 minutes (LED Digital Display) | ||
+ | Temperature Setting: RT-176℉/ | ||
+ | Transducer Quantity: 10 sets | ||
+ | Tank Size (L x W x H): 20.9" x 12.8" x 7.9" / 53 x 32.5 x 20 cm | ||
+ | Product Size (L x W x H): 20.9" x 12.8" x 13.4" / 53 x 32.5 x 34 cm |
