| Both sides previous revisionPrevious revision | |||
| en:palvelut:matrix [19.07.2026 22:14] – [Element Desktop app] Jana Lumi | en:palvelut:matrix [19.07.2026 22:15] (current) – [Element for Mobile devices] Jana Lumi | ||
| Line 15: | Line 15: | ||
| - Install the Element app. **Please note that you do not need to create a new account during installation !**\\ \\ [[https:// | - Install the Element app. **Please note that you do not need to create a new account during installation !**\\ \\ [[https:// | ||
| - | - Configure Element by pressing the button\\ \\ [[https:// | + | - Configure Element by pressing the button\\ \\ [[https:// |
| - | - Check that the server is changed to hacklab.fi (NOT matrix.org which is the default) | + | - Check that the server is changed to hacklab.fi (NOT matrix.org which is the default) |
| - | - Scroll to the bottom of the login window and select Hacklab SSO login \\ \\ {{: | + | - Scroll to the bottom of the login window and select Hacklab SSO login \\ \\ {{: |
| - Select Tampere and log in with your [[https:// | - Select Tampere and log in with your [[https:// | ||
| - Logging in requires a token. ** [[? | - Logging in requires a token. ** [[? | ||
