fi:tyokaluja:ompelukoneet [14.10.2021 17:39] – added images sandplumfi:tyokaluja:ompelukoneet [20.10.2025 17:04] (current) – external edit 127.0.0.1
Line 6: Line 6:
 === Juki DDL-8500 lukkotikkikone – industrial sewing machine === === Juki DDL-8500 lukkotikkikone – industrial sewing machine ===
 {{ :file:juki_ddl8500-luminix.jpg?200 |Juki DDL8500}} {{ :file:juki_ddl8500-luminix.jpg?200 |Juki DDL8500}}
 +[[https://www.youtube.com/watch?v=KHHk3dz0Y2s |Threading Guide JUKI DDL-8500 & 8700 Industrial sewing machines]] (YouTube)
 +{{ :file:ddl-8700_manual.pdf |Juki DDL-8700 Manual}} (pdf)
 +{{ :file:ddl-8500_p.pdf |Juki DDL-8500 Parts List}} (pdf)
 +The Organ needles are for use in the Juki machines and are stored in the drawer below the machine:
 +{{:file:organ_needles_juki-hollypoer.png?direct&200|}}
 +== LOCKSTITCH or STRAIGHT SEWING MACHINES ==
 +DO NOT switch the bobbin cases!
 +  * If the stitch is uneven or messy, check the thread tension and adjust the screw if necessary. The thickness of the thread also affects the bobbin case.
 +The quality of the stitch is also affected by the needle.
 +  * The right kind of needle is required!
 +  * The thickness of the material/thread to be sewn affects the size of the needle.
 +  * Check the needle and if it is broken, replace it.
 +Wind the bobbin on the right side of the machine.
 +  * When winding,
 +     *• Raise the presser foot up.
 +     *• Take the thread out of the needle eye.
 +     *• “Drive” to full to allow the oil to circulate in the device properly.
 +  * The bobbin must rotate clockwise in the housing.
 +Clean the machine after use.
 +  * The machine has hinges to allow the machine to tilt backwards.
 +  * The machine can be cleaned with compressed air.
Line 13: Line 49:
 === Rimoldi 263-46-3MD-05 tasosaumakone joustava – coverstitch machine === === Rimoldi 263-46-3MD-05 tasosaumakone joustava – coverstitch machine ===
 +18.7.2023 Kone muutettu 2-neulaiseksi ja 3-lankaiseksi. Langankatkaisuleikkuri poistettu. /jenniplatina
 {{ :file:rimoldi_263-luminix.jpg?200 |Rimoldi 263}} {{ :file:rimoldi_263-luminix.jpg?200 |Rimoldi 263}}
 +Tikkiesimerkki
 +{{ :tyokaluja:tikkiesimerkki2.png?200 |tikkiesimerkki}}
Line 23: Line 65:
 {{ :file:strobel-luminix.jpg?200 |Strobel}} {{ :file:strobel-luminix.jpg?200 |Strobel}}
 +[[https://www.youtube.com/watch?v=LoNjvhtYg3w |Strobel 141 40 Fur-Sewing Machine Single Thread Overseaming Machine For Fur]] (YouTube)
 +[[https://www.youtube.com/watch?v=fAhZT1j4BBY |STROBEL Kl. 72 FF, Fur/ Leather Industrial Sewing Machine*Made in Germany*]] (YouTube)
 +=== Jaguar Epochlock 055D ===
 +{{ :tyokaluja:jaguar_epochlock_055d.png?200 |Jaguar}}
 +=== Singer ===
 +{{ :file:singer_graduate_714_sewing_machine.pdf |Singer 714 Manual}} (pdf)
