| fi:tyokaluja:ompelukoneet [15.10.2021 14:12] – added YouTube links sandplum | fi:tyokaluja:ompelukoneet [20.10.2025 17:04] (current) – external edit 127.0.0.1 | ||
| Line 8: | Line 8: | ||
| - | [[https:// | + | [[https:// |
| + | The Organ needles are for use in the Juki machines and are stored in the drawer below the machine: | ||
| + | == LOCKSTITCH or STRAIGHT SEWING MACHINES == | ||
| + | DO NOT switch the bobbin cases! | ||
| + | * If the stitch is uneven or messy, check the thread tension and adjust the screw if necessary. The thickness of the thread also affects the bobbin case. | ||
| + | The quality of the stitch is also affected by the needle. | ||
| + | * The right kind of needle is required! | ||
| + | * The thickness of the material/ | ||
| + | * Check the needle and if it is broken, replace it. | ||
| + | Wind the bobbin on the right side of the machine. | ||
| + | * When winding, | ||
| + | *• Raise the presser foot up. | ||
| + | *• Take the thread out of the needle eye. | ||
| + | *• “Drive” to full to allow the oil to circulate in the device properly. | ||
| + | * The bobbin must rotate clockwise in the housing. | ||
| + | Clean the machine after use. | ||
| + | * The machine has hinges to allow the machine to tilt backwards. | ||
| + | * The machine can be cleaned with compressed air. | ||
| Line 16: | Line 49: | ||
| === Rimoldi 263-46-3MD-05 tasosaumakone joustava – coverstitch machine === | === Rimoldi 263-46-3MD-05 tasosaumakone joustava – coverstitch machine === | ||
| + | 18.7.2023 Kone muutettu 2-neulaiseksi ja 3-lankaiseksi. Langankatkaisuleikkuri poistettu. / | ||
| + | Tikkiesimerkki | ||
| Line 29: | Line 68: | ||
| [[https:// | [[https:// | ||
| + | === Jaguar Epochlock 055D === | ||
| + | === Singer === | ||
