Next revision | Previous revision | ||
tyokaluja:ompelukoneet [14.10.2021 17:24] – created sandplum | tyokaluja:ompelukoneet [20.01.2024 16:31] (current) – added Jaguar serger section and image Holly Poer | ||
Line 4: | Line 4: | ||
- | === Juki DDL-8500 lukkotikkikone – industrial sewing machines === | + | === Juki DDL-8500 lukkotikkikone – industrial |
+ | == LOCKSTITCH or STRAIGHT SEWING MACHINES | ||
+ | * When winding, | ||
=== Rimoldi 27.01 saumuri joustava – 3-thread overlocker machine === | === Rimoldi 27.01 saumuri joustava – 3-thread overlocker machine === | ||
+ | 18.7.2023 Kone muutettu 2-neulaiseksi ja 3-lankaiseksi. Langankatkaisuleikkuri poistettu. / | ||
+ | Tikkiesimerkki | ||
=== Union Special saumuri === | === Union Special saumuri === | ||
=== Strobel === | === Strobel === | ||
+ | === Jaguar Epochlock 055D === | ||
+ | === Singer === | ||
