tyokaluja:ompelukoneet [14.10.2021 17:39] – added images sandplum | tyokaluja:ompelukoneet [20.01.2024 16:31] (current) – added Jaguar serger section and image Holly Poer | ||
Line 6: | Line 6: | ||
=== Juki DDL-8500 lukkotikkikone – industrial sewing machine === | === Juki DDL-8500 lukkotikkikone – industrial sewing machine === | ||
+ | == LOCKSTITCH or STRAIGHT SEWING MACHINES == | ||
+ | * When winding, | ||
Line 13: | Line 49: | ||
+ | 18.7.2023 Kone muutettu 2-neulaiseksi ja 3-lankaiseksi. Langankatkaisuleikkuri poistettu. / | ||
+ | Tikkiesimerkki | ||
Line 23: | Line 65: | ||
+ | === Jaguar Epochlock 055D === | ||
+ | === Singer === | ||
