| fi:projekteja:olkiluoto3torttu [19.04.2023 13:08] – Robert Rozanski | fi:projekteja:olkiluoto3torttu [19.04.2023 22:31] (current) – Robert Rozanski | ||
| ====== Olkiluoto3torttu ====== | ====== Olkiluoto3torttu ====== | ||
| - | The third unit of the Olkiluoto power plant has finally started | + | The third unit of the Olkiluoto power plant has finally started |
| - | The structure of the cake is inspired by the look of the power plant: alternating brown and white mousse layers sandwiched between black base and top: | + | The structure of the cake is inspired by the look of the power plant: alternating brown and white mousse layers sandwiched between black base and topping: |
| Line 12: | Line 12: | ||
| * 39 digestive biscuits (assuming 15g/ | * 39 digestive biscuits (assuming 15g/ | ||
| * ~185g of black tahini | * ~185g of black tahini | ||
| - | * ~1kg of hazelnuts or 800g of roasted hazelnut paste/ | + | * ~1kg of hazelnuts or 800g of roasted hazelnut paste/ |
| * 2 white chocolates (2*128g - I used a " | * 2 white chocolates (2*128g - I used a " | ||
| * 200ml of 3.5% milk | * 200ml of 3.5% milk | ||
| Line 40: | Line 40: | ||
| - Allow it to cool down outside of the oven | - Allow it to cool down outside of the oven | ||
| - Install the plastic sheets - we do it now, because they would be destroyed in the oven | - Install the plastic sheets - we do it now, because they would be destroyed in the oven | ||
| - | - then put the whole thing into the freezer (with the baking tray). Just remove one of the drawers and put the baking tray in | + | - Put the whole thing into the freezer (with the baking tray). Just remove one of the drawers and put the baking tray in |
| - | - The top: | + | - The topping: |
| - Put the remaining 7 biscuits and 30g of tahini into the chopper, mix/chop as previously | - Put the remaining 7 biscuits and 30g of tahini into the chopper, mix/chop as previously | ||
| - Keep the mix in the fridge for later use | - Keep the mix in the fridge for later use | ||
| - | - Clean the | + | - Clean the chopper - you will need it later for the hazelnuts |
| - The hazelnut butter/ | - The hazelnut butter/ | ||
| - Roast the hazelnuts: you can use temperature between 150-175°C, the higher the quicker is the process, but also the easier it is to overdo the roasting. The peels should crack and the nuts should get light brown/ | - Roast the hazelnuts: you can use temperature between 150-175°C, the higher the quicker is the process, but also the easier it is to overdo the roasting. The peels should crack and the nuts should get light brown/ | ||
| Line 63: | Line 63: | ||
| - each layer calls for: 100ml of milk, 240ml of cream, 128g white chocolate, 1 teaspoon of gelatin | - each layer calls for: 100ml of milk, 240ml of cream, 128g white chocolate, 1 teaspoon of gelatin | ||
| - whip the cream (all of it) | - whip the cream (all of it) | ||
| - | - melt chocolate in the milk suing microwave of a water bath, mix well | + | - melt chocolate in the milk using microwave of a water bath, mix well |
| - prepare gelatin like before, mix with the chocolate/ | - prepare gelatin like before, mix with the chocolate/ | ||
| - let it cool a bit and mix it gently with the whipped cream - the mix will be more of a liquid than the hazelnut, don't worry | - let it cool a bit and mix it gently with the whipped cream - the mix will be more of a liquid than the hazelnut, don't worry | ||
| Line 72: | Line 72: | ||
| - Sprinkle the biscuit-tahini mix, you can use a butter knife to spread it around gently. Alternatively, | - Sprinkle the biscuit-tahini mix, you can use a butter knife to spread it around gently. Alternatively, | ||
| + | I didn't take many pictures during the baking but here are some: | ||
| + | the base before baking: | ||
| + | hazelnuts getting turned into paste: | ||
| The whole process of making the layers is a bit time-consuming, | The whole process of making the layers is a bit time-consuming, | ||
