fi:tyokaluja:sla-tulostin [23.06.2022 22:19] – peoinas_gmail.comfi:tyokaluja:sla-tulostin [11.11.2025 18:52] (current) – Wiki admin
-//This article is a work in progress//+Lue tämä ja lisäksi ennen käyttöä lue läpi tulostetut oppaat.
-====== Elegoo Mars SLA-printer (resin printer) ======+====== Formlabs Form 2 SLA Printer ======
-{{:tyokaluja:elegoo-mars.jpeg?200|}}+Hacklabilla on Formlabs Form 2 stereolitografia (SLA) -tulostin. Tulostin on maalaushuoneessa vetokaapissa.
-The hacklab has a first-generation Elegoo Mars SLA resin printer. The printer is located inside a fume hood in the painting room.+{{:tyokaluja:form2.jpg?400&nolink}}
-===== Printer Specifications =====
-**Printing area:** 120 x 68 x 155 mm\\ +===== Tulostimen tekniset tiedot =====
-**X/Y Resolution:** 0.047 mm (2560 x 1440 pixels)\\ +
-**Layer height:** Depends on resin; usually 0.05 mm\\+
-===== Preparing the Model =====+Tulostusalue: 145 x 145 x 175 mm\
 +X/Y -resoluutio: 140 microns (0.14 mm)\
 +Kerroskorkeus: 25, 50, 100, 200 microns (0.025, 0.05, 0.1, 0.2 mm)\
 +UV aallonpituus: 405 nm\
-You can print any 3D model as long as it fits in the print area. The most common file format is STL. Models can be found online or created using CAD software, Blender, etc.+===== Mallin valmistelu =====
-Models must be prepared using a slicing application before the printer can print them. The recommended application is ChiTuBox, which can be found on at least some of the computers at the lab. ChiTuBox can also add supports, make holes (for resin drainage) and hollow out the model (to conserve resin). Selecting the correct printer profile (Elegoo Mars) and the correct resin profile in ChiTuBox will give you workable default settings. If there is no profile for the resin you are using, consult the resin bottle.+Tulostimella voi tulostaa minkä tahansa 3D-mallin, kunhan se mahtuu tulostusalueelle. Yleisin tiedostomuoto on STL. Malleja löytyy netistä tai niitä voi tehdä CAD-ohjelmistoilla, Blenderillä, jne.
-After the model is sliced, put it on the USB stick found attached to the printer, then plug the USB stick into the USB extension cable next to the printer.+Ennen tulostusta malli tulee slaissata käyttäen slaissaussoftaa. Tämä tehdään PreForm-ohjelmalla, joka on suunniteltu erityisesti Formlabsin tulostimille.
-===== Working with the Printer =====+Supporttien luominen PreForm-ohjelmassa hoituu seuraavasti: Lataa STL-malli ohjelmaan ja käytä ohjelman tarjoamia työkaluja supporttien generointiin. PreForm osaa optimoida tulosteen rotaation siten, että se vaatii minimaalisen määrän supporttia.
-==== Resin Safety & Hygiene ====+===== Tulostimen käyttö =====
 +==== Hartsiturvallisuus ja -hygienia ====
-**ALWAYS WEAR SAFETY GOGGLES WHEN WORKING WITH RESIN. NO EXCUSES.**+HARTSIN KANSSA LÄTRÄTESSÄ KÄYTETÄÄN //AINA// SUOJALASEJA. EI MUTTIA. Mielellään sellaisia silmät sivultakin suojaavia.
-Resin is generally **very** toxic (as the red warning symbols on the bottle suggest). Wear safety glasses at all times when working around the printer, and do not touch the resin with bare skin and definitely do not ingest it. The resin causes chemical burns; it will not immediately burn skin, but it //will// immediately burn your eyes. If you get it on your skin, wipe it off with paper and then wash it off with running water immediately. If you get it in your eye, rinse the eye for 15 minutes and go to the hospital ASAP.+Hartsi on yleisesti ottaen melko myrkkyä (kuten pullossa olevat varoitukset kertovat). Käytä aina suojalaseja kun työskentelet printterin parissa äläkä koske hartsiin paljain käsin äläkä varsinkaan järkkää sitä silmiisi tai suuhusi.
-When working with resin, it is good to follow a clean hand & dirty hand hygiene practice. Wear a nitrile glove on one hand; this is the only hand that will ever touch resin, working ends of tools, the build plate of the printer, and anything else that comes in direct contact with resin. Your other hand is the clean hand; this is the only hand that will ever touch tool handles, the printer screen or anything else that should not come in direct contact with resin.+Pitkällä aikavälillä hartsi on allergisoivaa ja kontakti voi kehittyä hartsiallergiaksi vaikkei sinulla sitä entuudestaan olisi.
-With appropriate precautions resin is easy to work with, so don't be too afraid of it.+==== Tulostimen valmistelu ====
-==== Preparing the Printer ====+Kytke tulostin päälle sen takapuolella olevasta virtakytkimestä. Nosta suojakupu ylös.
-Turn the printer on using the power switch on the back side of the printer. Lift off the red plastic cover.+Katso tulostimen pohjalla olevaan hartsiammeeseen. Hartsi säilyy hyvänä kuvun alla useita viikkoja, mutta se voi kerrostua. Sekoita hartsia varovasti ennen käyttöä. Jos hartsi näyttää jo yksiväriseltä, sekoita sitä silti; se saattaa vaan teeskennellä.
-Make sure there is resin in the resin basin at the bottom. Odds are there already is resin in the basin; this is fine, as the resin will stay good for many days or weeks. However, it separates over time, so you will have to mix the resin in the basin before printing, as well as make sure there aren't any hard bits of resin floating around in it. The easiest way to do this is to wear a nitrile glove and mix the resin with your finger until it becomes uniform in colour (if it appears uniform already, mix it anyway; it could just be pretending).+Jos ammeessa oleva hartsi on mennyt huonoksi, se tarvitsee vaihtaa. Pitkään seissyt hartsi muodostaa kerroksen astian pohjaan ja estää valon pääsyn. Ennen tulostamisen alkamista, tyhjennä suodatin vanhasta hartsista ja tarkista kalvon kunto.
-If the resin in the basin has gone bad, you'll have to change it. **TODO: how to change the resin**+Varmista että tulostuslevy, amme ja pyyhkijä on asetettu kunnolla ja kiristetty.
-Make sure the build plate (the part at the top that dips in and out of the resin) is attached and tightened.+Käännä suojakupu takaisin tulostimen päälle.
-Set the red plastic cover back over the printer.+==== Tulostaminen ====
-==== Printing ====+Valitse kosketusnäytöltä tiedosto, jonka haluat tulostaa. Varmista esikatselusta että se on oikea tiedosto ja paina starttia.
-Select the file you want to print on the touchscreen. Verify that the preview and print time look about right and press start.+Seuraa ensimmäisen muutaman kerroksen tulostamista varmistuaksesi siitä, että kaikki on OK.
-Observe the first couple of layers to make sure everything is going OK. The build plate should descend into the resin, reach the bottom, lift up a little, then descend again to touch the bottom. It will remain there for about 60 seconds (whatever you set the first layer exposure time at). Then it'll lift up a little, descend, and expose the second layer, which should take about 8 seconds. If things are still looking alright at this point and there are no weird crunching noises and resin isn't leaking out and the printer isn't on fire, it is safe to leave the printer unattended. You won't be able to actually see the print for a long time anyway as it will be upside down suspended in the resin.+==== Tulosteen irrottaminen ====
-==== Detaching the Print ====+Kun tulostus on valmis, tulostuslevy nousee maksimikorkeudelle ja pysyy siinä.
-Once the print is finished, the build plate will lift out of the resin to its maximum height and stay there.+==== Tulosteen puhdistaminen ====
-At this point put a nitrile glove on your other hand as detailed in the resin hygiene section above. Loosen the big hand screw at the top of the printer using your clean hand, then detach the build plate by pulling it towards yourself -- it will slide off horizontally. The build plate is covered in resin, so only touch it with your gloved dirty hand.+Tarkista, että pesurissa on riittävästi isopropanolia.
-Using a scraper, carefully detach the part from the build plate. It is alright to scrape the build plate with a metal scraper, but do it gently at a low angle to not leave any deep marks and to avoid damaging your print. Remove any supports from the print and wipe off excess resin using a paper towel.+Avaa tulostuslevyn lukitus nostamalla päällä olevaa vipua. Siirrä tulostuslevy tulosteineen pesuriin.
-==== Cleaning the Print ====+Kun pesu on suoritettu, poista printti pesurista ja irroita tuloste tulostusalustasta.
-{{ :tyokaluja:anycubic-wash-and-cure.jpeg?200|}}+Aseta tuloste kovettimeen. Käynnistä kovetin.
-Next to the printer is an Anycubic Wash and Cure machine, which is used for washing and curing prints. Remove the yellow plastic cover of the machine. **Do not touch the cover or any part of the machine or the container with your gloved dirty hand.** Take the lid off the large cleaning fluid (the fluid is isopropyl alcohol) container and place it in the Anycubic. There are little grooves to help you align it, but there is no mechanical connection; the mixer at the bottom is rotated using magnets.+Kun kovettuminen on suoritettu, tuloste on valmis.
-Put your print in the metal washing rack, then lower the rack into the cleaning fluid container. The handle fits into slots near the top of the machine. Put the yellow plastic cover on the machine. Set the machine to Wash mode using the control panel, and adjust the time to your liking (2 or 4 minutes should be enough). Start the machine and wait for the cleaning program to run. The machine will beep once the program is finished. +==== Siivoaminen ====
-After the program is finished, lift the rack up, remove your print, and then rattle the rack against the edges of the container to get most cleaning fluid and loose pieces of plastic off of it before hanging it back up on the tool rack you found it on. Close the container lid tightly.+Puhdista käytetyt työkalut ja tulostuslevy. Siivoa ympäriinsä lennelleet muovinpalaset ja roiskeet. Pidä työpiste siistinä ja turvallisena.
-Finish cleaning your print up by hand by wiping off any remaining loose material and drying it using paper towels. Insert the acrylic platter into the Anycubic. It will slot into the axle at the bottom of the machine. Place your print on the acrylic platter and close the machine lid. Set the machine to Cure mode, adjust the timer to 6 minutes and press start. Once the program is done, flip your print upside down to expose the bottom and run it through the cure program again.+===== ProtoArt Universal Cartridge =====
-Your print should now be done.+Tulostimeen on hankittu (mutta ei vielä otettu käyttöön) ProtoArtin Universal Cartridge, joka mahdollistaa kolmannen osapuolen hartsien käyttämisen menettämättämättä tulostimen toimintoja (pyyhkijä, altaan automaattinen täyttö ja lämmitys), kuten formlabin tarjoamassa "open mode":ssa.
-==== Cleaning Up ====+{{:tyokaluja:unicart.jpg?400}}
 +[[https://cartridge.protoart.net/install/software]]
 +Kokonaan tämä ei meitä kuitenkaan vapauta, vaan aina hartsityyppiä vaihdettaessa tai kun on tulostettu noin 2 litran verran, on tämä siru resetoitava yllä olevan linkin takaa löytyvää "cartridge configuratoria" käyttäen. ProtoArt tarjoaa 10 resetointikertaa, joiden loppuessa lisää saa ostettua hintaan 45€/10 resetointikertaa.
 +**Universal Cartridgea käytettäessä on muistettava aina tarkistaa ennen tulostuksen aloittamista, että pohjan venttiili ei vuoda. Tulostuksen lopuksi tulee tarkistaa onko venttiili päästänyt hartsia tulostusaltaaseen liikaa, eli onko hartsin pinta yli ylemmän viivan. Jos näin on, on puruventtiili vaihdettava.** ProtoArt suosittelee vaihtamaan venttiilin noin 3 litran välein. Normaalistihan venttiilin tarvitsee kestää vain yhden pullon verran, koska pulloja ei ole suunniteltu täytettäviksi. ProtoArtin mukaan jotkin CamelBak-retkeilyvälinevalmistajan puruventtiilit (Bite valve) sopivat tähän käyttöön.
 +Lisätietoa saatavilla olevien hartsiprofiilien kanssa yhteensopivista hartseista löytyy monien hartsivalmistajien omilta sivuilta, esimerkkinä vaikka tämä: [[https://www.liqcreate.com/supportarticles/form1-form2-compatible-resin/]]
 +==== Softan käyttö ====
 +Yllämainittu configurator-ohjelma soittaa kotiin jokaisella käyttökerralla. Meitä kiinnostaa kovasti näiden keskustelujen sisältö, joten teimme työkalusta version, joka kirjaa verkkoliikenteensä selkokielellä lokitiedostoon. Tämä versio löytyy esiasennettuna loungessa olevalta koneelta, jonka kotelossa lukee "minilla", ja lisäksi läbin verkkolevyltä.
 +**Jos kirjoitat universal cartridgeen uudet asetukset**, tee se käyttäen tätä lokittavaa versiota ohjelmasta ja ota lokit talteen verkkolevylle kansiosta //%localappdata%\UniCart\//, jotta voidaan myöhemmin tehdä data-analyysiä, jos tarvii. Älä ylikirjoita vanhoja lokeja kun teet näin, laita uudet lokit verkkolevylle esim. päivämäärän mukaan nimettyyn kansioon.
-Clean every tool you used with isopropyl alcohol and paper towels. Clean both sides of the build plate and reattach it to the printer. Clean off any spills, bits of plastic etc. Put used paper towels and nitrile gloves in the trash. **Replace all the paper towels covering the work surfaces after you're done.** You should leave the printer nicer than you found it.
